Share from 0:00
0:00
Multi-Layer PCB Routing in TSCircuit: Fixing Circuit-to-SVG & Auto-Routing Algorithms
A 3-hour deep dive into implementing layer-specific obstacle avoidance and fixing trace and pad rendering inside of circuit-to-svg
In this extensive development stream, Seve guides contributors through a complex implementation of multi-layer PCB routing in TSCircuit. The video covers:
  1. Debugging and fixing the Circuit-to-SVG library to properly render traces on different layers with correct colors
  2. Refactoring the auto-routing data set to support layer-specific obstacles
  3. Implementing layer information in the I-Jump A* algorithm for multi-layer routing
  4. Testing and verifying the new multi-layer routing capabilities
Key technical aspects covered include:
  • Modifying SVG generation to support layer-specific rendering
  • Refactoring obstacle definitions in the auto-routing algorithm
  • Updating the Simple Route JSON format to include layer information
  • Implementing layer-aware obstacle avoidance in the I-Jump A* algorithm
  • Debugging cross-repo dependencies and fixing build processes
This video is ideal for contributors familiar with TSCircuit's codebase and looking to understand the intricacies of implementing multi-layer PCB routing. It showcases real-time problem-solving and the iterative nature of complex feature implementation across multiple interconnected libraries.
Discussion about this video
User's avatar
Ready for more?
